Edit Waterfall Plots
In this tutorial, you will learn how to work with the Axes panel, query data, edit curve attributes, and use the Edit Legend dialog.
Plot attributes, such as style, color, and weight are located in the Curve Style panel. This panel also allows you to contour the surface and edit the legend, too.
Axis attributes such as labels, color, and scaling can also be modified using the Axes panel
Figure 3.
The Values panel allows you to retrieve individual point data on any curve in the active window. When a point on a curve is selected, the point data is displayed on the panel and in a bubble in the graphics area of the screen.
Open the Session File and Create a 3D Chart Window
Create a Frequency versus Time Waterfall Plot
Work with the Axes Panel
Query XYZ Values Using the Coordinate Info Panel
Edit the Curve Attributes and Contour the Plot
Use the Edit Legend Dialog
- Click Edit legend.
                Experiment with the following:
 - Click on a number in the legend box and enter a new value.
 - Press Enter.
 - The edited value is displayed in bold font. The remaining values linearly interpolate.
                Add a header and footer to the legend.
- Activate the Header check box and enter text in the text box.
                        Click the font button
 and change the font type and size.
                     - Click OK.
 - Activate the Footer check box and enter text in the text box.
                     - Click OK.
 - Click Apply.
                Change the color of a legend band.
- Click on a color band.
 - Select a new color.
 - Click OK.
 - Change another color.
                Interpolate colors between two color bands.
- Click Interpolate.
 - Click on the first changed color.
 - Click on a second changed color.
 - The colors between the two selected colors are interpolated.
 - Click Apply.
Save Legend Settings for Future Use
Once you have completed your legend settings, you can save them for future use. Items that can be saved are listed in the Save options section.
 in the Response field for Data curves:.
 from the Display mode options in the panel.
