Headers
Show or hide the table column headers and row numbers.
                Figure 1. View new features for Altair HyperWorks 2023.
Load an Excel CSV file into TableView.
Display the data contained in the selected TableView cell.
Displays the data contained in the currently selected TableView cell.
Overlay reports for summary tables.
Refresh the table data.
TableView supports cell math references in a Templex expression, like the support of curve math references in HyperGraph.
From TableView, use the Table Browser to view the current session and all pages and windows it contains in a hierarchical display.
From within a cell, row number, or column header in TableView, right-click to display the following context menu items.
                Figure 1. © 2023 Altair Engineering, Inc. All Rights Reserved.
