Modal Analysis Summary
Add a summary of the modal analysis as a table to the report.
From the Report Ribbon, Add Modules tool group, click
 and select Modal Analysis
                                Summary module.Or
Right-click at the Report or Chapter level and select .Restriction: This module is available for HyperView only.- Below are the properties associated with Modal Analysis Summary module:
Figure 1.- Name
 - Provide the name for the Modal Analysis Summary module.
 - Basic
- Model
 - Select the required HyperView page or window of the session.
 - Load Cases
 - Select the load cases to be used for looping. By default, Active is selected.
 - Advanced
- Define Precision
 - A numerical value to define the precision for the modal frequencies.
 - Define Threshold
 - Define the threshold values for the modal frequencies.
 - Auto Split Table
 - Provides the function to split up tables automatically based on the space available in the slide or page.
