Add Modules to Report Structure
To add modules to the report structure, follow the below steps:
                From the Report ribbon, Add Module group, right click the type of modules to be
                    added to the Report structure.
Figure 1.Or
Modules can be added at the Report root level or under a chapter.
- Model Info- Model Info module enables user to generate report
                                including various model details such as Component List, Connection
                                Statistic, Unit Systems and more.
Figure 2. - Validate- Validate group contains modules associated with high level
                                diagnostic information of the model such as model statistics, mesh
                                quality statistics, model checker summary and more.
Figure 3. - Results- Results module enables user to generate Loop Results,
                                Matrix Browser script and Model Analysis Summary as a table.
Figure 4. - Capture- Capture module enables user to capture the entire session
                                content or selected pages and windows as images to a Document or
                                Presentation report.
Figure 5.
Refer Add Modules for details on each modules.
                Click Run.
                All items marked for execution are executed, and the output and previews are generated.
