Test Models
Use the Model Testing tools to test models and review test results.
                From the PhysicsAI ribbon, select the Test
                        Machine Learning Model tool.
Figure 1.The Test Model dialog opens. -
                Select a model and Dataset.
Figure 2. -
                Click OK.
                The Model Testing dialog opens.Tip: You can also open the Model Testing dialog by selecting the Review Test Results tool.
Figure 3. - Click Detailed Report to open the View Score Report.
 - In the Model Testing dialog, select a Run ID and click Show Results to view the results in the modeling window.
 - Close the Model Testing dialog.
