Imprint Geometry
Use the Imprint tool to imprint geometry or mesh onto target surface/lines or elements creating new edges/fixed points or a mesh patch respectively.
Imprinting points on lines or surfaces creates geometry vertices similar to using the Split: Interactive tool. Imprinting surfaces onto surfaces imprints all of the source surfaces' edges onto the target surfaces.
.- Uncheck node list to change the source entities.
 - Node list/elements imprint to CAD surface is not possible.
Imprinting elements / FE geometry to elements / FE geometry obeys post
                imprint options of FE tab in
- Split multiple surfaces with multiple lines at once.
 - Use the Split: Interactive tool to untrim previously imprinted surfaces.
 - Use the Stitch tool to suppress imprinted edges.
CAD Options
- Maximum imprint distance
 - Use maximum imprint distance between source and target geometry.
 - Maximum distance
 - Enter an imprint distance.
 - Line extension method
 - Select a line extension option.
 - Keep line endpoints
 - Keep line endpoints when extending lines.
 - Surface imprint method
 - Select which lines to imprint.
 - Do not imprint internal edges
 - Skip internal edges and common edges of selected surfaces.
 - Do not imprint near existing edges
 - Skip edges too close to pre-existing features.
FE Geometry Options
 - Maximum distance
 - Post imprint options
- None
 - Simple method to imprint source on target surface.
Figure 2. - Create patch between imprinted edges
Figure 3. - Move target imprint edges to source
Figure 4. - Move source to target
Figure 5.
 - Create elements in
 - Select to create imprint or patch elements in the following:
- Source component
 - Current component
 - Destination component
 - Do not remesh/rebuild extension
 - Use to avoid remesh or rebuild of the patch elements.
Figure 6. - Closed loop for node list selection
 - Use to close the loop of selected node list.
Figure 7. - Do not add fixed points/edges on nodes imprint
 - Use to imprint nodes on FE geometry without fixed points or edges.
Figure 8.
