Create Boxes
Use the Solids: Box tool to create boxes with solid or bounding surfaces.
                From the 3D ribbon, click the Solids > Box tool.
Figure 1. -
                Create a box using one of the following methods:
Method Procedure By Plane - Click By Plane from the selector on the guide bar.
 - Left-click on geometry or in empty space to create the corner point for the box's base.
 - Hold the middle mouse button and drag to manipulate the vector defining the plane for the box's base.
 - Click the Play button on the guide bar.
 - Left-click and drag in empty space to draw the box's base.
 - Release the mouse button and move the mouse to set the height of the box.
 - Left-click to create the box.
 - Click Plane on the guide bar to define another box in a new plane.
Free Drawing - Click Free Drawing from the selector on the guide bar.
 - Left-click and drag on geometry or in empty space and draw the box's base.
 - Move the mouse to set the height of the box.
 - Left-click to finish creating the box.
Fit To - Click Fit To from the selector on the guide bar.
 - Select Surfaces, Solids, or Components from the selector on the guide bar.
 - Left click to select a corresponding surface, solid, or component on the model. A box will display.
 - Use the move tool to modify the box, if necessary.
 - Click the Play button on the guide bar to finish creating the box.
                Modify the size and location of the box in the following ways:
- Resize the box by editing the length, width, and height in the microdialogs and pressing Enter.
 - Click on a face of the box and drag the slider to adjust its dimension.
 - Click
 to translate
                        and rotate the box using the Move tool. - Click
 to fit the box
                        around a selected object. - Click
 to fill the
                        shape.
Tip: While placing or editing the box, use snap points to snap to predefined points on your model, such as surface boundary fixed points
                or mid points of surfaces.
