Objectives
Objective entities define and store an objective for an optimization problem.
Objectives do not have a display state in the modeling window.
Nastran Cards
| Card | Description |
| DESOBJ | Selects the DRESP1 or DRESP2 entry to
                  be used as the design objective. Note: Objective function, can be in or out of the
                    load step; Belongs in the subcase section.
| MAXMIN | Objective functions for maxmin problems. |
| MINMAX | Objective functions for minmax problems. |
OptiStruct Cards
| DESOBJ | Selects a single response definition as the objective
                function of an optimization, or to select system response definitions when the
                objective function is the least squares sum of these definitions. The
                  DESOBJ command also indicates if this response is to be
                minimized or maximized. Note: Subcase Information Entry
| MINMAX or MAXMIN | Selects normalized response or system
                identification definitions as the objective function for a "Minmax" or "Maxmin"
                optimization. Note: Subcase Information Entry
Radioss Cards
| DESOBJ | Specifies a response as the objective function of an optimization. |
