HyperWorks
HyperWorks
2023
  1. Home
  2. Entities and Solver Interfaces
  3. Collectors and Collected Entities
    Collectors are named organizational containers for collected entities. Collected entities are nameless entities which must reside within one, and only one, collector. Collected entities are mutually exclusive to a collector.
  4. Components and Geometric/FE Entities
  5. Finite Element Entities
    Supported finite element entities.
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Meshing and Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • Squeak and Rattle Director
  • PhysicsAI
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
  • Collaboration Tools
Index
HyperWorks
2023
HyperWorks
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
    • Collectors and Collected Entities
      • Include Files and SolverSubmodels
      • Assemblies
        Assemblies collect and organize sub-assemblies and components into hierarchical data structures which are intended to reflect the data structure of the product being modeled.
      • Components and Geometric/FE Entities
        • Components
          Components collect and organize points, lines, surfaces, solids, elements and connectors. Components are intended to be organizational containers for the geometry and FE idealization of a physical part which makes up a product.
        • Geometric Entities
        • Finite Element Entities
      • Load Collectors, Loads and Equations
      • Part Assemblies and Parts
      • System Collectors and Systems
      • Vector Collectors and Vectors
      • Beamsection Collectors and Beamsection
      • Bags
        Bags collect and organize entities.
      • Multibodies
        Multibodies collect and organize ellipsoids, multibody planes, and multibody joints and are typically used in multi-body analysis.
    • Named Entities
      Entities which are given a name but are not collected or organized into containers.
    • Morphing Entities
      Entities used for morphing the shape of FE model.
    • Optimization Entities
      Entities used to set up optimization problems.
    • Control Cards
      Control card entities create solver control cards such as results file I/O options, CPU and memory limits, and others.
    • Undefined Entities
      Undefined entities are entities that will not be written to the solver deck.
    • Solver Encryption Entities
      The encryption of solver entities is used to translate entity data into an undisclosed language.
    • Element Property and Material Assignment Rules
      Element property and material assignment rules are based on the current user profile (solver interface).
    • Supported Cards
      Supported cards organized by solver.
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
HyperWorks
HyperWorks
2023
  1. Home
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
  • Elements
  • Nodes
