Browsers provide a structured view of model data, which you can use to review, modify, create, and manage
the contents of a model. In addition to visualization, browsers offer features like search, filtering, and sorting,
which enhance your ability to navigate and interact with the model data.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Use PhysicsAI to build fast predictive models from CAE data. PhysicsAI can be trained on data with any physics or
remeshing and without design variables.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
Stitch HL is a unique type of Connector as it can only be Absorbed as an Analysis type
Connector. It can be used to define a weld between 2D-2D, 2D-3D, and 3D-3D. These
Analysis Connectors cannot be Unrealised or Realised, only Updated.
It is intended for identifying Stitch welds within an existing model and creating sets to
define the Heat Affected Zones (HAZ), as well as define the details according to the
standard: EN 15085 3.
The HAZ is defined through a EL2MAT set of the Elements that lie within the tolerance. In
the situation where there are cross over welds, the weld connecting a Part with the
lowest Yield Stress will contain the elements. In the situation where there isn’t a
Yield Stress, or both are the same Material/Yield Stress, the longer of the Connectors
will then use the elements.
