Mass and COG Review
In the modeling window, display mass, center of gravity, or moment of inertia as markers.
- From the Aerospace menu, select .
                Define the following options:
Option Description Entity - From the drop-down menu, select components or elements.
 - Select the entities on the model.
 - Click
 upon completion to return to the
                                    tool.
Datanames - From the list, select one of the following dimensions:
- Mass
 - COG coordinate, X, Y, or Z
 - Moments of inertia components expressed from the origin (IXX, IYY, IZZ).
 - Moments of inertia components expressed from the component center of gravity (IXXcog, IYYcog, IZZcog, and so on).
Marker Options - Display the entity ID, dataname, and/or marker plot color.
Shape Options - If you select Draw Shape, select the
                                    shape type and enter a radius value.Draw Shape displays markers that change in size depending on the value of each component.
 - Click Draw.
