Synch Between HyperMesh and HyperView
Allows you to have the same system defined in both HyperMesh and HyperView.
- You have a session with a model in HyperMesh and the same model with results in one or more HyperView windows.
 - Create one or more coordinate systems in HyperMesh that have not been previously used in the model where the results have been extracted.
 - Open the tools in HyperMesh and select the system (s) you want to create in HyperView.
 - HyperView client (s) are displayed in a user interface where the systems that have to be created can be selected.
