Define Nodal Equivalence
Use the Nodal Equivalence tool to select the node location to perform direct nodal equivalence instead of running it through either component or element selection.
Using this tool, you can apply to the selected nodes an equivalence calculated at the mid-point, at the lowest ID or at the highest ID, with a certain tolerance. You can also retain at the lowest or highest ID.
- From the menu bar, click .
 - Make your selections in the dialog.
 - Click Apply.
