Create Quick Sets
Use the Quick Set tool to create relevant elements that are masked to ease further selection/generation.
Create an assembly structure from a .csv file definition.
Use the Boolean Operations tool to list elements and create new sets.
Select either elements or nodes from the model and find the sets that are collected.
ON THIS PAGE
ON THIS PAGE
