Create 0D Elements Between Connected Nodes
- From the menu bar, click Aerospace > Connections > Zero Length Elements.
 - Select the nodes to be disconnected.
                Click Create Between Connected.
                The nodes are disconnected and the elements are created.
Figure 1. Select Connected Nodes
Figure 2. Elements Created Between Connected Nodes After Disconnecting
