Create Splines
Use the Spline tool to define the coupling/interface between the structure model (through the SET1 entity) and the aero model (through the AELIST entity), respectively called structure and aero surfaces.
- From the Aeroelasticity ribbon, click the satellite
                        icon
 that appears when you hover over the Spline tool to
                        open the Aeroelasticity Browser.
