Visualize Modal Deformation, Stress, or Strain Contours
                From the Plot tools, click the Contour tool.
                    Figure 1.  - Select the appropriate Result type and the direction using the drop-down menus.
                Click Apply.
Note: The Stress or Strain results in the flexible body will be available if Stress or Strain was requested while generating the flexible body.
