Set Wizard Paths
The Set Wizard Path dialog allows you to set the directories in which the several files are stored.
List of files set in the dialog:
- Assembly wizard file
 - Task wizard file
 - MDL standard include file
 - Wizard library directory
 - Report log file
See the Set Wizard Paths Dialog topic for additional information.
