Defining an Expression Output
An expression based output can be used to generate outputs based on solver run time functions. Solvers like MotionSolve and ADAMS provide several functions to track various outputs during the solution process.
- From the Result Type drop-down menu, select Expressions to create an expression based output request.
                Click inside any of the text boxes (F2,
                        F3, F4,
                        F6, F7,
                        F8) and enter a solver expression that needs to be
                    printed to the result files.
                Tip: Use the Expression Builder to create complex expressions by clicking inside the desired text box and selecting
 from the trio of buttons at the top of the panel. The Expression Builder
                        provides access to all solver function data members in the model, as well as
                        many math and signal processing functions in HyperGraph. See Use the Expression Builder for additional information.Use MotionView entity data members to maintain a parametric relation with the entity and the output being measured.
For example, the expression
`DX({b_ball.cm.id})uses theidof the user specified CM marker (implicit marker created by MotionView at a user given cg point) of the bodyb_ball. - Optional:
                Select the Define custom names and units check box in
                    order to provide custom names and units for the F2, F3… output channels.
- Additional columns (Cnames and Cunits) are available for entering the custom names and units.
 - The custom names along with the units will appear as component names for the channels while plotting the results in HyperGraph.
