Create a Study
- Be sure that at least one MDL model is active when HyperStudy is invoked.
                From the Application menu, select HyperStudy.
                HyperStudy is launched.
Figure 1. -
                Under Start, click on New Study.
                Tip: You can also select New from the File menu or click the New button
 on the toolbar.The HyperStudy - Add Study dialog is displayed.
Figure 2. - Enter a Label and variable name (Varname) for the study.
 - Browse to the location for the study folder (output from study), and check the Create study directory in subfolder, based on Varname box if a new folder study-specific folder should be created.
                Click OK.
                The HyperStudy - Add Study dialog is closed and a new study is created. The application view will contain the Explorer/Directory page on the left side, along with a work area.
Figure 3. Creating a Study in HyperStudy
