Add and Select an Entity Using Geometry
MotionView allows you to create and select certain types of entities in a collector by picking an edge or surface of certain Graphic entities. To enable this feature, activate the Allow CAD feature recognition for picking option in the Build Model section of the Preferences dialog.
- Point
 - Vector
The Graphic entities that allow such operations are: Cylinder, Box, and CADGraphics.
