Display the Tracing Lines
                Select a marker from the list or from the graphics window, then choose from the
                    following options.
- Show Tracing Lines
 - Displays the marker and the tracing line. When deselected, only the marker is shown.
 - Show Image
 - Deactivate this option to turn off the image and only display the tracing lines.
 - Window track size
 - The Window track size is used in an algorithm which attempts to
                                estimate the movement of the pixels near the point selected. In some
                                cases, the video pixel you select to be traced can be traced
                                incorrectly during animation. Changing this value also changes the
                                accuracy of the traced pixels. Adjusting the Window track size value
                                can improve or decrease the marker tracing. Higher or lower values
                                are not consistent for all of the points in a video. For some
                                points, a higher value may work better. In other points in a video,
                                a lower value may work better. This setting is currently a global
                                setting for all markers in a given video. If you find points that
                                you need traced and the Window track size needs to be higher for
                                some and lower for others, the current workaround is to create a
                                duplicate window with the same video and use one with a lower value
                                and the other window with a higher value.
You can use the slider bar,
, to increase or decrease the value
                                    shown in the text box. You can also enter a new value directly
                                    into the text box.
 - Click Apply.
