X Source
Use the X Source tab to select the X Type, Request, and Component data.
- Choose Data File
 - Click the file browser button to locate the data file. X Source types, requests, and components are automatically populated based on multiple input selection or Y Source file selections.
 - Types Filter
 - Enter the keyword to use as a filter when searching for types. Access the search string history from the drop-down menu.
 - Types List
 - Displays the types found (with or without a filter) from the file selected. Select a type to populate the Requests list.
 - Requests Filter
 - Enter the keyword to use as a filter when searching for requests. Access the search string history from the drop-down menu. Select Match Y Request to use as an additional filter.
 - Requests List
 - Displays the requests found (with or without a filter) from the selected type. Select the requests to populate the Components list.
 - Components Filter
 - Enter the keyword that you want to use as a filter when searching for components. Access the search string history from the drop-down menu. Select Match Y Component to use as an additional filter.
 - Components List
 - Displays the components found (with or without a filter) from the selected requests.
