Use Math as a Data Source
- From the Define panel, under Source, select Math.
- Define the vector using the curve calculator to create a mathematical expression.
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
Edit existing curves and add new curves to the current plot.
ON THIS PAGE
ON THIS PAGE
