Move Curves
- From the Complex plot toolbar, select the Scales, Offsets, and Axis Assignments panel.
 - Select the curves from the list or pick them from the window.
 - Turn on the X check box and enter a new X coordinate for the origin of the curve in text box.
Or
- Turn on the YP check box and enter a new YP coordinate for the origin of the curve in the text box.
Or
- Turn on the YM check box and enter a new YM coordinate for the origin of the curve in the text box.
                Click Apply to move the start point for the selected
                    curve(s).
                The selected curves are moved to the right for positive values and to the left for negative values.
