Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
The HyperGraph Plot Browser is located in the tab area sidebar and allows you to view the HyperGraph plot structure.
Within the Plot Browser, there are seven predefined browser view modes, accessible via the first row of icons within the Plot Browser.
The Plot Browser contains several ways to filter your plot data to display specific plot entities in the browser.
From the Plot Browser, right-click on a highlighted entity to access the following context sensitive menu options.
When a plot entity is selected from the plot browser tree, its properties and values are displayed in the Properties Table, also referred to as the Entity Editor. The fields displayed in the Properties Table are dependent on the curve or entity type selected from the Plot Browser tree.
When you select Reference from the Properties Table, HyperGraph sets the curve as the reference curve.
When shading curves in HyperGraph, you can customize the areas of the plot to shade and have flexibility with respect to displaying curves with shaded areas.
From the Properties Table/Entity Editor, select from several options when positioning notes.
When you select Notes from the Plot Browser, you can activate a "mouse over", or Minimize, option from the Properties Table/Entity Editor.
The Properties option gives you more control over how the curve names appear in the plot legend.
Use the floating Entity Editor to edit attributes for plot entities.
Use the entity selector to specify the plot entity to select.
Use the View toolbar to control the view and display of your plot, the curve color display, and plot curves instantly.
Set default parameters for HyperGraph plot types.
From the HyperGraph modeling window, right-click to display HyperGraph context menus.
Axis attributes, such as labels, color, and scaling, can be edited using the Plot Browser, Entity Editor, or the Axes right-click context menu.
The Synchronize Windows feature allows you to manipulate multiple plots in multiple windows at the same time.
ON THIS PAGE
ON THIS PAGE
