Edit a Datum Line
                From the modeling window, select a datum line.
                The datum attributes are displayed in the Plot Browser.
Figure 1. Plot Browser, Datum Lines View
OR
                From the modeling window, select a datum line,
                    right-click, and select Edit.
                The datum line Entity Editor is displayed.Note: Double-click on a datum line also opens the floating Entity Editor.
Figure 2. Entity Editor for Datum Lines -
                Edit the datum attributes as needed.
                Please select from the following options:
- Name
 - The name of the datum line.
 - Label
 - The datum label displayed in the plot window, which can be edited as needed.
 - Visibility
 - Select to display the datum line in the plot window.
 - Layer
 - Position
 - The location of the datum line on the curve. Enter a new value to
                                reposition the datum line. The value can be any of the following:
- A single value.
 - A math expression that returns a single value (without curly brackets, {}).
 - A math expression as a function of x or y, with x or y being the horizontal or vertical axes values, respectively.
 - Associated Axis
 - The axis associated with the datum.
 - Type
 - Horiztonal or veritical.
 - Font Settings
 - Edit the font settings for the datum line label.
 - Label Location
 - Position the datum line label with respect to the datum line.
 - Line Style, Thickness, and Color
 - Select a line style and thickness from the drop-down menus. Click the color icon to edit the datum line's color.
