Use Values as a Data Source
- From the Define panel, select Values.
 - Enter values in the table.
 - Click Apply.
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
Plot curves for multiple runs and multiple subcases for a component.
Create and edit curves.
When creating a curve using the Create Curves by File dialog, the curve name is defined by a Templex expression instead of a fixed string.
Create macros that produce curves and notes for plots.
Edit curves within a specified range and orientation.
Retrieves individual point data on any curve in the active window. When a point is selected, the point data is displayed on the panel.
Calculates statistics over a specified range on a curve.
Add horizontal and vertical datum lines to plots.
Annotate plots using notes.
Curve scaling, offsets, and axis assignments can be applied to multiple curves using the Move panel.
