Use a File as a Data Source
- From the Bar Chart Define panel, select .
                Click the file browser button,
, and select a data file.
             - Select a vector data source by specifying the Type, Request, and Component.
 - Click Apply.
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
Edit existing bar charts individually and add new bar charts to the current plot.
