Display Point Data in Decibels
For XY Plots:
For Polar Plots:
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
Retrieve individual point data on any curve in the active window. When a point is selected, the point data is displayed on the panel.
ON THIS PAGE
For XY Plots:
For Polar Plots:
ON THIS PAGE
