Settings Files
Settings files include command<#>.tcl and hwsettings.xml.
The list of files written is detailed below.
command<#>.tcl
The command file is a command history file containing the commands executed in HyperMesh whenever any operation is performed. This file can be used to rerun operations or as a basis for determining the commands required to automate a given process. By default, the command file is written to the start-in directory for each session. It is possible to customize the location where this file is written to using the HM_COMMANDFILE_DIR environment variable. Note that on Linux, the command file is named command.tcl.
hwsettings.xml
- HW_SETTINGS_DIR environment variable. If this is defined, the search stops even if the file does not exist.
 - My Documents directory on Windows or ~/.altair on Linux.
