HMNAME COMP
Import comment to sort and organize entity types into HyperMesh.
HMNAME COMP id, name, property_id, property_name, id_pool
HyperMesh Comments
Input
- entity_type
 - COMP
 - id
 - Unique entity type identification number.
 - name
 - A name given by you to help organize the model or describe the entity.
 - property_id
 - Unique entity type identification number. Valid only for OptiStruct and Nastran.
 - property_name
 - A name given by you to help describe the entity. Valid only for OptiStruct and Nastran.
 - id_pool
 - Internal solver ID pool. Valid only for OptiStruct and Nastran.
Supported Solvers
OptiStruct
Radioss
ANSYS
LS-DYNA
Nastran
