Train a Classifier
Before you begin, you must generate clusters.
                From the Design Explorer ribbon, Evaluate tool group, click the
                        Results Explorer tool.
Figure 1.The Results Explorer browser opens. -
                In the Results Explorer browser, click
                    ExpertAI.
                In the Classifier section, click Train Classifier.
                A classifier is automatically created based on the clusters.
                Create a constraint.
- Right-click the classifier and select Create Constraint from the context menu.
 - In the dialog, enter a name.
 - Select a cluster.
 - Enter a value for the lower bound.
                Click Optimize and select
                        Fit-Based or
                    Solver-Based.
                An optimization runs based on the selection.
