Create Gauge Inputs
Use the Gauge tool to create design variables based on the thickness of selected properties.
                From the Design Explorer ribbon, click the Gauge
                    tool.
Figure 1. -
                Select properties.
                Gauge input values can be entered in one of the following ways:
- As a continuous range of values, where the lower and upper bounds are specified as a percentage plus or minus its nominal value.
 - As a continuous range of values, where the lower and upper bounds are specified specifically.
 - As a list of discrete values.
                In the microdialog,
- Select how you would like to define the input values, then either specify the lower and upper bounds or specify a list of valid discrete values.
 - Click Create.
