Elements
              | Radioss |
              OptiStruct |
              | /ADMAS |
              CONM2 |
              | BEAM |
              CBEAM |
              | BRIC20 |
              CHEXA |
              | BRICK |
              CHEXA, CPENTA, CTETRA |
              | PENTA6 |
              CPENTA |
              | SH3N |
              CTRIA3 |
              | SHELL |
              CQUAD4 |
              | SPRING + PROP/SPRING (TYPE 4) |
              CBUSH1D |
              | SPRING |
              CBUSH |
              | TETRA4 |
              CTETRA |
              | TRUSS |
              CROD |
    Contacts
                | Radioss |
                OptiStruct |
                | TYPE2 |
                TIE |
                | /TYPE24 |
                CONTACT, AUTO, PCONT, PSURF |
                | /TYPE25 |
    Loads
                | Radioss |
                OptiStruct |
                | /CLOAD, /FUNCT |
                FORCE, DLOAD, TLOAD, TABLED1 |
                | /GRAV |
                ACCEL2 |
    Materials
              | Radioss |
              OptiStruct |
              | MAT/COMPSH (LAW 25) |
              MAT9ORT** |
              | MAT/ELAST (LAW 1) |
              MAT1 |
              | MAT/HONEYCOMB (LAW 28) |
              MAT9ORT + MATX28* |
              | MAT/PLAS_JOHNS (LAW 2) |
              MAT1 + MATX02* |
              | /MAT/PLAS_TAB |
              MAT1, MATS1, TABLEMD |
              | MAT/PLAS_TAB (LAW 36) |
              MAT1 + MATX36* |
              | MAT/VOID (LAW 0) |
              MAT1 + MATX0* |
      *Only when you click Yes in the RadiossBlock to OptiStruct
          conversion tool dialog.
      **The values of NU23 and NU31 are set to default values on conversion.
    Properties
              | Radioss |
              OptiStruct |
              | PROP/BEAM (TYPE 3) |
              PBEAM + PBEAMX* |
              | PROP/SH_SANDW (TYPE11) |
              PCOMP** |
              | PROP/SHELL (TYPE 1) |
              PSHELL + PSHELLX* |
              | PROP/SOLID (TYPE 14) |
              PSOLID + PSOLIDX* |
              | /PROP/SPR_BEAM |
              PBUSH |
              | PROP/SPR_BEAM (TYPE 13) |
              PBUSH + PBUSHT |
              | PROP/SPR_GENE (TYPE 8) |
              PBUSH + PBUSHT |
              | PROP/SPR_PUL (TYPE 12) |
              PBUSH |
              PBUSH1D |
              | PROP/TRUSS (TYPE 2) |
              PROD |
      **Only material, ply thickness, and ply angle is converted.
