OptiStruct to Radioss Conversion Mapping
Elements
| OptiStruct | Radioss |
| CONM2 | /ADMAS |
| CWELD | Mesh less weld (feabsord, fe realize using HEXA)  |
| CELAS1/CELAS2 CDAMP1/CDAMP2 (0 length)  |
              /SPRING |
| PLOTEL | Plot element |
| RBAR | /RIVET |
| RBE2/RBE3 | /RBODY |
| RJOINT | /RLINK |
| CBUSH (When using vector)  |
              /SPRING3N |
| CBUSH1D | /SPRING2N |
| CBAR/CBEAM/CBEND | /BEAM |
| CROD | /TRUSS |
| CONROD | /TRUSS and /PROP/TRUSS |
| CTRIA3/CTRIAR CTRIA6 (Change to 1st order before convert)  |
              /SH3N |
| CQUAD4, CQUADR, CSHEAR CQUAD8 (Change to 1st order then convert)  |
              /SHELL |
| CTETRA4 CTETRA10 (Change to 1st order then convert)  |
              /TETRA4 |
| CHEXA8/ CPENTA6 CHEXA20/ CPENTA15 (Change to 1st order then convert)  |
              /BRICK |
Properties
| PBAR/PBEAM (Only single section PBEAM is supported)  |
              /PROP/BEAM |
| PBUSH | /PROP/SPR_GENE |
| PBUSH1D/PDAMP/PELAS | /PROP/SPRING |
| PROD | /PROP/TRUSS |
| PSHELL/PSHEAR | /PROP/SHELL |
| PSOLID | /PROP/SOLID |
Materials
| MAT1 | /MAT/ELASTIC |
| MAT8 | /MAT/LAW19 |
