Elements
              | LS-DYNA |
              Nastran |
              | *ELEMENT_MASS  |
              CONM2 |
              | *ELEMENT_INERTIA |
              CONM2 |
              | *ELEMENT_BEAM  |
              CBAR  |
              | *ELEMENT_SHELL |
              CTRIA3,CQUAD4, CQUAD8, CTRIA6 |
              | *ELEMENT_SOLID |
              CTETRA4/CHEXA8/CPENTA6 |
              | *CONSTRAINED_SPOTWELD |
              RBAR |
              | *ELEMENT_PLOTEL  |
              PLOTEL |
              | *CONSTRAINED_INTERPOLATION |
              RBE3 |
              | *CONSTRAINED_NODE_SET |
              RBE2 |
              | *ELEMENT_DISCRETE |
              CELAS1 |
    Properties
              | LS-DYNA |
              Nastran |
              | *SECTION_SOLID |
              PSOLID |
              | *SECTION_SHELL |
              PSHELL |
              | *SECTION_BEAM |
              PBAR, PBARL |
      *SECTION_BEAM with ELFORM 1 is mapped to the PBARL property.
      *SECTION_BEAM with ELFORM 2 is mapped to the PBAR property.
    Materials
      All the LS-DYNA materials are mapped MAT1 in Nastran.
    Boundary Conditions
              | LS-DYNA |
              Nastran |
              | *BOUNDARY_SPC |
              SPC |
              | *LOAD_NODE_POINT |
              FORCE, MOMENT |
              | *LOAD_SEGMENT |
              PLOAD4 |
              | *INITIAL_TEMP |
              TEMP |
    Coordinate System
              | LS-DYNA |
              Nastran |
              | *DEFINE_COORDINATE_NODE |
              CORD1R |
              | *DEFINE_COORDINATE_SYSTEM  |
              CORD2R |
