HyperWorks
HyperWorks
2023
  1. Home
  2. Get Started
  3. User Interface
    Explore the user interface.
  4. Tcl Console
    The Tcl Console enables you to enter and execute Tcl/Tk commands instead of using the user interface.
  5. External Window Curve Editor
    CurveEditor class, its member functions, and their use-cases are described here.
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Meshing and Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • Squeak and Rattle Director
  • PhysicsAI
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
  • Collaboration Tools
Index
HyperWorks
2023
HyperWorks
  • What's New
  • Get Started
    • User Interface
      • Title Bar
        The title bar displays the name of the file that is currently opened, along with the active product and user profile.
      • Pages and Windows
        The main display area of the user interface is called a page. Each page can contain up to 16 windows.
      • Ribbons
        The ribbon allows you to quickly access tools and standard functions, and is located along the top of the user interface. Click on an icon to open the related tool. Hovering over a group of icons may reveal additional tools.
      • Modeling Window
        The modeling window is where your model is displayed.
      • Status Bar
        The status bar displays information pertaining to the currently loaded model, active tools, current collectors, and snap filter options.
      • Toolbelt
        Use the toolbelt to quickly access frequently used tools.
      • Context Menus
        Context menus are floating menus that are accessed by right-clicking on elements in the user interface. They provides immediate access to a short list of commands that are contextually relevant to the selection.
      • Guide Bars
        Guide bars guide you through a series of commands, required inputs, and options necessary to complete a workflow that is specific to a tool.
      • Tcl Console
        • HyperView Tcl Console Commands
          Overview of the HyperView commands that can be entered in the Tcl Console to manipulate the model.
        • External Window Curve Editor
          • Curve Editor
            Creates a curveEditor object.
          • Curve Related Functions
        • Intellisense
          The Intellisense window allows you to quickly locate commands for a given handle, as well as their parameters.
      • HWC Console
        The HWC Console, with the command line, supports auto-completion and interactive help and allows easy modification and re-execution of commands.
      • Message Log
        The Message Log lists the actions performed in the current session. The dialog also provides you with information about your file (warnings, errors, and so on).
      • Command Files
        Command files can be used to create new command scripts that perform automation, or to recover previously performed steps.
      • Dock and Undock Parts of the User Interface
        Certain parts of the user interface, such as browsers, toolbars, and panels, can be undocked and repositioned as needed.
    • Adjust the View
      View controls enable you to control the view and display of your model in the modeling window.
    • Find and Search for Tools
      Quickly find and open the tools and browsers that are available from the ribbons, as well as create entities and solver cards.
    • Selection
      Select and deselect entities to modify with other tools. Selected entities are outlined to indicate their selection state.
    • Move, Snap, and Orient
      Translate, rotate, and align the model.
    • Measures
      Use the Measure tool to measure length, angles, radii, areas, volumes, centers of gravity, and bounding boxes.
    • Working with Entities
      Learn how to manipulate entities.
    • Undo-Redo
      Undo and redo actions.
    • Keyboard Shortcuts and Mouse Controls
      Default keyboard shortcuts and mouse controls.
    • SpaceBall/SpaceMouse Devices
      Supported SpaceBall or SpaceMouse devices.
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
HyperWorks
HyperWorks
2023
  1. Home
  2. Get Started
  3. User Interface
  4. Tcl Console
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
  • Curve Editor
