Common terminology used with the collaboration features is described in this section.
Content refers to any information stored in a library. Content Definitions encapsulate information about the types of information managed by the HyperMesh libraries.
Use the Organize browser to organize your data.
There is one out-of-the-box repository, Personal (managed repository).
Libraries can be created within a repository to logically organize or group the contents stored within a repository. Repositories can contain one or more libraries.
A workspace is a local directory where files are retrieved from the vault so that they can be viewed and/or modified.
Content inside a library can be organized by folders and categories.
The Content Browser is the main component of the Organize browser and displays library content in many ways, according to options available from the toolbar.
The Properties panel shows metadata names and values for the selected object in the Content Browser.
Use the Content Browser to set your preferences.
Use references to link one content to another. Typical examples would be a solver deck master file that refers to its include files, or a HyperMesh session file that refers to the results files used in the session.
By selecting individual or groups of files and/or folders, contents can be added to libraries in bulk.
The Explore dialog provides enhanced capabilities for searching for and retrieving data, beyond what is provided from typical file browse dialogs.
Use the Subscribe dialog to register or subscribe to parts or items of interest that reside within a corporate PDM system. Once the parts have been subscribed to, the dialog helps to ensure that you are working with the latest information by allowing you to quickly check whether any subscribed to parts have been updated, and to seamlessly retrieve updated information and files for those that have.
MotionView supports a limited version of interface with Collaboration Tools.
Collaboration Tools comes with an out-of-the-box profile, which is tailored specifically for organizing and managing material information and data.
ON THIS PAGE
ON THIS PAGE
