Signal Processing
Overview of Fast Fourier Transform, phenomena, windowing, Filtering Frequency Response, functions, blocking, and Hilbert Transform.
The first fundamental tool of signal processing is the Fourier Transform. The Fourier Transform is used to map time-domain data into the frequency domain. The frequency-domain representation of a curve (or signal) contains the same information as the time-domain representation, but in a different form. Each representation is useful in certain circumstances. The most basic use of the frequency-domain representation is to view the frequency content of a signal.
In order to perform a Fourier Transform on a computer, the signal to be transformed must be digitized. The basic requirement for all discrete Fourier Transforms is that the discrete input data be sampled at a constant frequency, such that all time intervals are identical. If the input data is not evenly sampled, the discrete Fourier transform will be incorrect.
Figure 1. Discrete Fourier Transform and Fast Fourier Transform
HyperView, MotionView, and HyperGraph have both a regular discrete Fourier Transform and a Fast Fourier Transform. The advantage of the discrete Fourier Transform is that no zero-padding occurs. This is important because zero-padding can distort the phase angle spectrum. The advantage of the Fast Fourier Transform is in computation speed, which varies with the number of points.
x=0:10:.01
y=sin(2*pi*5*x)+sin(2*pi*15*x)+sin(2*pi*20*x)+sin(2*pi*33*x)
Now
create a second curve in a different window on the same page. It should
be:x=freq(p1w1c1.x)
y=FFTmag(p1w1c1.y)
The result shows spikes at each of the frequencies present in the initial equation, that is, at 5 Hz, 15 Hz, 20 Hz, and 33 Hz.
Notice that there will also be other spikes at frequencies not present in the initial equation, at 67 Hz, 80 Hz, 85 Hz, 95 Hz. This is due to phenomena caused by sampling the data, and is discussed below.
y = fold(FFTmag(p1w1c1.y))
Only the left half of the spectrum is shown.
FFT Phenomena
- Aliasing
- Due to the nature of sampled data, only a limited frequency range can be
examined using discrete Fourier transforms. The valid frequency range is
from 0 to half of the sampling frequency. This is known as the Nyquist
frequency. Any frequencies outside of this range are erroneously
attributed to frequencies inside the range. These frequencies will be
"folded" back into the valid range.
Figure 3. - Leakage
- An assumption made by the Fourier Transform is that the signal being
transformed is periodic, allowing the integral in Equation 1 to go from
0 to the signal duration rather than from 0 to infinity. This means
that, in effect, the FT algorithm is concatenating the signal with
itself indefinitely. At the endpoints of the signal, discontinuities
often occur. These discontinuities are very difficult to map to periodic
components. In fact, they require an infinite number of periodic
components. This, in turn, introduces spurious frequency components into
the resultant spectrum.
Figure 4.
Windowing
As described in the previous section, discontinuities at the end points of the signal introduce leakage. Leakage is undesirable because it distorts the true spectral characteristics of the signal. To eliminate leakage, not only must the end points of the signal have the same value, but they must also have the same slope.
Figure 5.
The value of the windowing function starts out very small, increases to a value of one in the middle, and then decreases symmetrically. When this function is multiplied by the input signal, it has the effect of damping out the ends of the signal. Thus, when the signal is concatenated with itself, no large discontinuities will be present since the end points should both have values and slopes close to zero.
Using a windowing function, however, alters the quantitative properties of a signal, such as the RMS. HyperGraph uses power correction in its windowing functions to eliminate this problem. HyperGraph also removes the mean (DC component) from the signal before windowing. This makes the windowing more effective and does not affect the frequency content of the signal.
A common way of viewing frequency domain representations of data is the power spectral density function or PSD. This function is the square of the magnitude spectrum scaled by the inverse of the duration of the signal. Assuming the input signal is in volts, the integral of the PSD with respect to frequency will give the RMS value, or total power, of the signal. By integrating only over a specific frequency range, the RMS of the signal due to frequency components in that frequency range can be determined.
Filtering
A common practice in signal processing is to smooth data by eliminating high-frequency components. This is done using a low-pass filter. It is called a low-pass filter because it only keeps low-frequency components and eliminates high frequency components. Thus, it only lets low-frequency components pass. Other types of filters are high-pass, band-pass, and band-stop, or notch, filters.
Figure 6. Low-Pass Filtered Signal
In order to specify which frequencies are to be removed, cutoff frequencies must be defined. For low- and high-pass filters, only a single cutoff frequency is necessary. For low-pass filters, frequencies below the cutoff frequency are passed, while the opposite is true for high-pass filters. Band-pass and band-stop filters require two cutoff frequencies, a low and a high. For a band-pass filter, only frequencies between the two cutoff frequencies are passed, while for a band-stop filter, only frequencies outside this range are passed.
One problem with this approach is that often the beginning and end of the filtered signal do not match well with the original data. This is due to the fact that data is missing on either side, making it more difficult to reconstruct the signal from the filtered frequency data. Also, if the signal does not have a number of points which are a valid number for an FFT, it will be zero-padded. In many cases, this causes the filtered signal to sharply tend toward zero at the end. In order to minimize this problem, often the input signal is concatenated with constant values equal to the last value, then filtered, and finally the added values are removed.
It is recommended that the mean be removed from a signal before it is filtered so the mean of the filtered curve is 0.00. Then, add the mean back after filtering to obtain the desired magnitudes. The mean may be left out altogether if the DC component is not desired.
Frequency Response Functions
A Frequency Response Function, FRF, is used to determine the frequency characteristics of a given system. The system must be quantified with an input signal and an output signal.
Figure 7.
For a system with a uniform gain and delay, the magnitude spectrum would be constant at the gain of the system and the phase spectrum would be linear with slope proportional to the system delay.
Blocking
Random data theoretically has no Fourier Transform, because it is aperiodic.
Therefore, in the Fourier Transform equation, , the upper
limit cannot be changed to the period of the signal. This would mean an infinite
amount of data would have to be collected in order to get the true Fourier Transform
of a random signal. In practice, this point is ignored. However, two random signals
from the same system will have vastly different spectral characteristics. In order
to circumvent this problem, a process known as blocking is often used.
In blocking, a single random signal is subdivided into many shorter signals. The frequency characteristics of each of the smaller signals are calculated, and then averaged. This takes advantage of a statistical property which states that if the frequency spectra of a large enough number of signals are averaged, the results will tend toward the true spectrum of the system.
However, by using this technique, the duration of each individual signal is lessened, resulting in poorer frequency resolution. Since the sampling interval is the same for each sub-signal as the original signal, the Nyquist frequency is not changed by blocking.
Hilbert Transform
Figure 8.
