view target
The coordinates of the point on the 3D model where the camera is focused on.
view target <target>
Arguments
- <target>
- XYZ coordinates of where the camera is pointing.
view target 2000 0.000425 -11509.070313
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Adjust the focal point offset.
View the clipping region.
Create new view.
Delete view.
Exports the view file as a text file to the specified directory.
Adjust the view to fit the model or selected objects in the modeling window.
View the focal length of the camera lens.
View the focal point offset.
Import a view file.
Updates the view orientation matrix of the current active window with the given sixteen float values.
Select a view angle.
Define which direction the top of the camera is pointing toward.
Perspective view angle.
View the lens position.
Sets the view projection type.
Rename an existing view.
Restores the current view parameters with the memorized view name.
The height of the camera sensor in millimeters.
The actual direction the top of the camera is pointing toward.
Set the z offset of a view.
Perform actions on XY plot files.
View manipulation.
