result scalar legendmax
Defines the legend's maximum value.
result scalar legendmax <value>
Arguments
- <value>
- Enter the legend's maximum value.
result scalar legendmax 14
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
Result loading.
Resets the legend for contour, vector, tensor, and iso based on the currently displayed parts.
Create and manage file sets for derived loadcases.
Create and manage iso plots.
Create and manage loadcases for derived loadcases.
Create and manage the contour plot.
Clears the contour plot.
Turns on/off discrete colors in the contour plot.
Clears the scalar plot from the modeling window.
Interpolates the contour colors from the undeformed shape, with a zero value, to the result variable reported from the solver.
Edits the contour plot's legend properties.
Enables the legend's maximum value.
Defines the legend's minimum value.
Enables the legend's minimum value.
Loads and plots scalar data types.
The multiplier for scaling all the result values.
Enter a value that will affect the contour value, contour min/max, and the legend min/max.
Displays the current scalar plot in the modeling window.
Set the current simulation.
Makes a subcase current.
Create and manage tensor plots.
Create and manage vector plots.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Perform actions on XY plot files.
Result loading.
