config reset
Resets all settings defined with the config command to the application defaults. All variables will be deleted.
config reset
config reset
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Set animation capture options to be used by all animation commands.
Set image capture options.
Set model configuration options.
Set report template options.
Set reader options.
Set the result math template.
Set planar and spherical section cut options.
Set user-defined variables.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Perform actions on XY plot files.
config reset
config reset
