animate bounce
Bounce animation option.
animate bounce <true/false>
Arguments
- <true/false>
- Turn on/off bounce mode.
animate bounce true
Animation controls.
Sets the animation frame.
Sets the animation frame rate.
Linear animation options.
Modal animation options.
Sets the animation mode.
Advance to the next frame.
Return to the previous frame.
Start the animation.
Stop the animation.
Transient animation options.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Perform actions on XY plot files.
Animation controls.
animate bounce true
