hm_viewrightside
Sets the model to the right side view.
hm_viewrightside
HyperMesh Tcl GUI Command
hm_viewrightside
None.
This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
The functionality of the HyperMesh Tcl Modify Command commands are available through Tcl. Additionally, commands that allow you to extract information from the HyperWorks database, such as entity ID numbers on a mark, a list of assemblies, component names, elements per component, nodes per element, node values, and so forth. These are known as HyperMesh Tcl Query Command commands. They are used to query information from the database or template system.
Allows rotation of the model by manipulating a virtual sphere.
Displays the collector selector widget for selecting a single collector/named entity.
Displays the HTML help for a specific book and topic.
Displays the include selector widget for selecting a single include.
Allows you to select a region to zoom into.
Clears the graphical marker created by hm_plotmarker.
Clears the graphical shape created by hm_plotshape.
Returns the display status of a collector.
Launches the Card Editor to edit a specific entity or mark of entities.
Launches the Tk control Card Editor to edit a text control card.
Displays a custom error message in the status bar.
Exits HyperMesh.
Create FBD panel or bar plots.
Controls certain options and of the HyperMesh GUI framework.
Returns the transformation matrix for the current view.
Provides a widget to define a direction/vector.
Get a filename using an open file dialog.
Get a floating point value using a dialog.
Returns the x, y, width and height of the modeling window.
Get an integer value using a dialog.
Queries the current load plot state.
Provides a widget to define a plane.
Get a string value using a dialog.
Returns the x, y, width and height of a window.
Control the highlighting of a single entity collector.
Control the highlighting of a list of entities.
Control the highlighting of a mark of entities.
Turn on or off the message box for ID Manager messages.
Launches the HyperBeam GUI with a specified beam section loaded by default.
Performs a dynamic pan of the model.
Plot engineering loads with various options.
Plots entity as either a vector or a contour plot.
Creates a graphical marker.
Creates a graphical shape.
Posts a pop-up for a selected entity.
Posts a pop-up for a mark of entities.
Redraws the HyperMesh window.
Registers an entity sub-type filter for usage by *createmarkpanel or *createentitypanel.
Registers a script or command to a keyboard shortcut.
Specifies if markers and shapes should be redrawn when the associated entity is modified.
Returns either the normal or parallel screen vector.
Use this command in conjunction with the creation of filters to add only entities of the stated type to the filter.
Use this command in Tcl procedures to show the user that HyperMesh is working.
Clears HyperMesh panels, and sets <procedure name> as a macro to be called.
Unregisters an entity sub-type filter for usage by *createmarkpanel or *createentitypanel.
Displays a custom user message in the status bar.
Sets the model to the bottom side view.
Rotates the model counter-clockwise about an axis oriented perpendicular to the screen.
Clears a saved view.
Rotates the model clockwise about an axis oriented perpendicular to the screen.
Rotates the model down about an axis oriented horizontally across the screen.
Fits the model view into the modeling window.
Sets the model to the front side view.
Sets the model to the isometric view.
Rotates the model left about an axis oriented vertically across the screen.
Sets the model to the left side view.
Returns the list of saved views.
Returns the view to the previous view.
Converts an x,y,z model coordinate to a modeling window coordinate.
Sets the model to the rear side view.
Rotates the model 180 degrees about an axis oriented vertically across the screen.
Rotates the model right about an axis oriented vertically across the screen.
View all components in shaded mode with no feature or mesh lines.
View all components in shaded mode with feature lines.
View all components in shaded mode with mesh lines.
Sets the model to the top side view.
Converts an x,y,z graphic window coordinate to a modeling windowcoordinate.
Rotates the model up about an axis oriented horizontally across the screen.
View all components in wire frame mode.
Capture a rectangular area of the screen and save it to the clipboard.
Capture a rectangular area of the screen and save it to a file.
Returns the value of certain HyperMesh window settings.
Provides a limited interface to the HyperMesh window.
Zooms into the model.
Zooms out of the model.
Returns information about hmbr3 browser views and selections.
The list of deprecated Tcl GUI commands, and the new commands to use.
The list of undocumented Tcl GUI commands.
ON THIS PAGE
hm_viewrightside
hm_viewrightside
None.
ON THIS PAGE
