*equation()
Defines an equation load in HMASCII format.
*equation (id,type,constant,independentnodexmax,dependentnode,dependentdof,collector)
HyperMesh HMASCII Command
Defines an equation load.
The *equation(), *inodes(), *idofs() and *icoeffs() blocks must be in the following order:
*equation()
*inodes()
*idofs()
*icoeffs()
- id
 - The ID of the equation.
 - type
 - The solver dependent type code for the equation.
 - constant
 - The constant for the equation.
 - independentnodesmax
 - The number of independent nodes.
 - dependentnode
 - The dependent node ID.
 - dependentdof
 - The dependent node degree of freedom.
 - collector
 - The ID of the collector that owns the equation.
*equation(100,1,2.5,3,350,3,2.0,5)
*inodes(5,6,7)
*idofs(135,135,135)
*icoeffs(0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.5)Errors
Incorrect usage results in an import error.
