@elemcountperinclude()
Returns the number of elements of a specific configuration and type for a specific component being exported to an include file.
@elemcountperinclude (entity_type, config, type, include_id,component_id)
HyperMesh Template Function
This function returns the number of elements of a specific configuration and type for a specific component being exported to an include file.
- entity type
 - The type of entity to be counted. Currently, this is restricted to be only elements.
 - config
 - The configuration of the elements to be counted. If set to zero, entities are counted regardless of their configuration.
 - type
 - The type of the elements to be counted. If set to zero, entities of the specified config are counted regardless of their type.
 - include_id
 - The ID of the include file.
 - component_id
 - The ID of the component.
To query the elements of config 104 and type 1 in include 1 and component 100:
*variableset(variable1,[@elemcountperinclude(104,1,1,100)])
    Version History
14.0
