Pareto Plot Post Processing
Plot the effects of input variables on output responses in hierarchical order (highest to lowest).
Plot the Effects of Variables on Responses in Hierarchical Order
- From the Post Processing step, click the Pareto Plot tab.
- Using the Channel selector, select the response to plot.Tip: Analyze multiple responses simultaneously by switching the Multiplot option to
(multiple plots) and selecting the responses to plot using the Channel Selector.
- Analyze the pareto plot.
The effect of input variables on output responses is indicated by bars. Hashed lines with a positive slope indicates a positive effect. If an input variable increases, the output response will also increase. Hashed lines with a negative slope indicates a negative effect. Increasing the input variable lowers the output response.
A line represents the cumulative effect.
- From the Channel Selector,
review the Ranked Inputs.
For more information, see Ranked Inputs.
Configure the pareto plot's display settings by clicking (located in the top, right corner of the work
area). For more information about these settings, refer to Pareto Plot Tab Settings.
Settings to configure the plots displayed in the Pareto Plot post processing tab.
- Effect curve
- Show line to represent the cumulative effect.
- # Top factors displayed
- Specify the number of input variables (bars) displayed in the
plot.Note: This setting does not change the calculated effects.
- Multivariate Effects
- Calculate the effect using all input variables simultaneously.
- Linear Effects
- Calculate the effect using each input variable independently.
- Include Interactions
- Include first order, two way interactions along with first order effects, and calculate interactions consistently with the choice of linear or multi-variate effects.
- Exclude dependent/linked inputs
- Only show the independent input variables.Tip: Excluding dependent/link inputs reduces redundant information.
Multivariate effect of an input variable is the difference between the output response values when the variable is at its lower and upper values while the remaining variables are held constant. All calculations are based on a single linear regression model including all variables.
Run | X | Y | F (X, Y) |
1 | 42.0 | 108.0 | 1385.4 |
2 | 54.0 | 156.0 | 2290.2 |
3 | 66.0 | 84.0 | 3421.2 |
4 | 78.0 | 132.0 | 4778.3 |
5 | 32.4 | 165.6 | 824.4 |
6 | 44.4 | 93.6 | 1548.3 |
is the reference regression model and intercept. A and coefficients, B and C, are calculated using the data set above.
A = - 2609.8
B = 88.6
C = 2.5
- Effect of X (lower = 32.4, upper = 78.0)
Since we are investigating the effect of X only, Y is held constant. For this example, use the mean value ( = 123.2).
- X = 32.4, Y = 123.2
- X = 78, Y = 123.2
- Effect of Y (lower = 84, upper = 165.6)
Since we are investigating the effect of Y only, X is held constant. For this example, use the mean value ( = 52.8).
- X = 52.8, Y = 84
- X = 52.8, Y = 165.6
Input Variable | Multivariate Effect |
X | 4040.4161 |
Y | 202.7087 |
