Quickly add input variables to your model by importing them from an Excel
spreadsheet.
In the Define Models step, click Import Variables.
The Excel spreadsheet opens.
Select input variables.
In the Excel dialog, click
Yes to begin selecting input variables.
The Excel - HyperStudy Input Selector
dialog opens.
In the spreadsheet, select the input variable's value and label
cells.
Note: You can select an input variable's value and label in two
consecutive rows or two consecutive columns.
The selected cells display in the Excel - HyperStudy
Input Selector dialog.
Click OK to import the selected input
variables.
To continue selecting input variables in other areas of the
spreadsheet, repeat steps 2.b and 2.c.
Click Cancel in the Excel - HyperStudy
Input Selector dialog to stop selecting input
variables.
Select output responses.
Yes to begin selecting output
responses.
dialog opens.
In the spreadsheet, select the output responses' value and label
cells.
Note: You can select an output responses' value and label in two
Click OK to import the selected output
responses.
To continue selecting output responses in other areas of the
spreadsheet, repeat steps 3.b and 3.c.
Input Selector dialog to stop selecting output
responses.
