Select Entities
Window Selection Settings
Change window selection settings from the modeling window right-click context menu.
- Window Select Disabled. Disable window selection. Allows for fast clicking without the risk of dragging a mini window.
- Window Shape. Change the shape of the selection window when you drag your mouse.
- Intersection - Select entities that are inside,
outside, or intersecting the window shape.Note: Intersection is available for elements, lines, and surfaces.
- Only Select Visible. Only select visible entities. Available for elements.
